04-02-2017 11:35 AM
I want to analyse a chaotic generator. And I need to make a bifurcation diagram. So I want to make a device, which will change the parameter in cycle and save the peaks of each simulation (of each iteration) and then make a bifurcation diagram. So I want to make it by using c++ code.
So I've found something like "instruction" but it explains the stuff pretty bad (here is the link: http://zone.ni.com/reference/en-XX/help/375482B-01/multisim/gaintestexample/#wp252103). For example, I want to test the GAINTEST model. So I don't really understand the first and the sixth points. Because when I launch the Vcvars32.bat through the cmd nothing happens. But the first point of the instruction claims that I should somehow set the inviromental variables.
And when I launch MAKE_DLL file through the cmd it says "file ifcpec.ifs was not found" (I put the screenshot). And beacuse of that I stuck at the begining.
Please help!!!
04-07-2017 11:32 AM
I have included environment variables manually, you can do it like the image attached.
Right click on the batch file and click edit, to see what it does and then, you can check if the variables were included
and check if you do have the file in the Windows directory
04-10-2017 11:03 AM
Thank you for reply!
I don't really understand what should I do with these files.. .Should I create environment variables? I really want to get the point of this thing...
04-10-2017 01:33 PM
According to it, the .bat file does it for you, once you run it, you can confirm that they are set, but first, make sure that you have the files in your computer
04-10-2017 01:41 PM
Yes, I do have this file. So I opened it through cmd (and also just clicking on it) .
And what should happen?
04-11-2017 05:24 PM
running the .bat was step 1, if the file is good then the variables should be set.
What else have you done? Have you followed the other steps?
04-12-2017 06:35 AM
I just want to create example gaintest model.
So I have "Ifspec.ifs" and "Cfunc.mod" files for my GAINTEST model.
As you can see on the photo, it can't create dll file.
And I don't really understand what these "cl" and "link" things are.
04-14-2017 11:56 AM
Well that appears to be a response in Russian. Have you run it through a translator to see what it says? Or if you can read Russian that would be helpful as well.
Mitchell Faltin | NI
04-14-2017 12:56 PM
Oh..I'm sorry.
It says that "cl" and "link" are neither internal or external commands nor batch files.
04-17-2017 07:15 PM - edited 04-17-2017 07:16 PM
I got the same error as you, it did produce the .c file but not the dll
It seems to be related to the environment,
http://stackoverflow.com/questions/8800361/cl-is-not-recognized-as-an-internal-or-external-command
What seems to be most likely is this: "The C++ tools are not being installed by default in Visual Studio" from this thread
