Multisim and Ultiboard
circuit board
sir give me basic block diagram and circuit diagram for interfacing with microcntroller 8051and serial communiction via RS 232 to Labview ..
"SB02"
(3,741 Views)
Accepted by Bhadresh
Hello Bhadu,
I'm a new user to Multisim, so this may not be exactly what you're looking for.
If you open the Example Finder and type in 8051, you'll find that there is a serial connection example.  The circuit looks like the picture below.
Unfortunately this circuit doesn't have the electrical connection to the RS 232 connector.  But it might be a start.
Patrick Allen: FunctionalityUnlimited.ca
(3,703 Views)
As I know, Printed circuit board is a non-conductive material with conductive lines printed or etched. Components like capacitors, resistors or active devices are generally soldered on the PCB. PCBs can be single-sided, double-sided and multi-layer.
(2,901 Views)
