Multisim and Ultiboard
create a DPDT relay
I am using Multisim 11.0.  I have been able to simulate a single pole double pole (SPDT) relay by using the "Relay1c Virtual".  But I would like to have a DPDT relay and also a 4PDT relay for simulation.  How can I create these?
(6,159 Views)
I am putting two SPDT relays in parallel to get a DPDT relay, it works but there must be a better way.
(6,150 Views)
Accepted by jmpz
Hi there,
If you only need this for simulation, you can place your 2 SPDT relays in a subcircuit or hierarchical block. You can then duplicate as many copies of the subcircuit as you want for your design.
Hope that helps.
Yi
Software Developer
National Instruments - Electronics Workbench Group
(6,099 Views)
With all the hundreds of complected objects available in Multisim I am SHOCKED that a simple DPDT is not one of them especially after 13 upgrades.  Is there any plans to bring any forward? Or at least a motor controller?
Thanks-
(3,722 Views)
It is not possible to knwo ehen exactly is going to include all , perhaps posting on the ideas exchange, will make developers to make it happen
(3,710 Views)
