Multisim and Ultiboard
pwm
Guys,
          this circuit in anex is about a buck converter. The circuit in the left is the pwm generator and the circuit in the right is the buck converter, I'm using a MOSFET as a switch, the potenciometer is the D parameter. But I don't know what is going wrong when I set the source of the buck converter to 20 V or anyother, the load tension is not 10 V as D=0.5.
I would appreciate any help.
(3,412 Views)
I am not sure how you plan on turning on the mosfet using 10V at the gate as the buck is operated from 20V. Also, I would suggest that you use a simple clock source to get the main power circuit to work and then proceed to more elaborate ways of generating the PWM.
Max
(3,411 Views)
The way of generating the PWM I think it's correct. I don't know about the MOSFET used in the buck converter, I think the mistake is in it.
(3,409 Views)
The problem is that the mosfet I'm using is not switching anyway.
(3,400 Views)
If you want a mosfet to turn ON, your gate voltage must exceed the source voltage by an amount specified in the datasheet (typically ~2V). You are driving the gate with 10V while expecting to keep ON a mosfet that would have a source of voltage of 20V. This is not a regime a mosfet can operate in. You need to either increase the gate voltage or drive it as a differential voltage across gate and source directly.
Max
(3,391 Views)
I increased the Vcc voltage but it's not switching anyway.
(3,381 Views)
your mosfet has on Rds of 5ohms which is twice as large as your load. You're getting a huge drop across it. This mosfet is not meant for this application; you need to use a power transistor and one with a much smaller Rds (e.g <100mOhm).
alternatively you can use an ideal voltage controlled switch (component SBREAK from the switch family).
Max
(3,376 Views)
