在 05-26-2017 02:31 AM
大家好,我正在做比赛项目,是关于激光采集,将myRIO接CMOS相机,用相机采集激光光斑,并进行图像处理,处理数据量较大,随后将处理结果与数据传回电脑,使用STM TCP协议,但是在使用过程中,第一个问题是启动下位机程序时时不时会出现error导致程序无法进行并自动停止。启动过程中出现创建TCP侦听器出错,7210001,这个问题一般是运行程序第二遍开始会出现,重启myRIO再启动程序没问题。
第二个问题是在运行过程中,经常会出现写入TCP数据错误,error 3970001,直接导致程序停止运行,重新启动程序,就会出现第一个侦听问题。
请问一下这两个问题该如何解决,谢谢~万分感谢
在 05-26-2017 02:30 AM
From Google translation:
Hello, I am doing the game project, is about laser collection, myRIO then CMOS camera, with the camera to collect laser light, and image processing, processing a larger amount of data, then the results and data will be transferred back to the computer, the use of STM TCP Protocol, but in the use of the process, the first problem is to start the next bit machine program from time to time error will cause the program can not be carried out and automatically stop. Start the process of creating a TCP listener error, 7210001, the problem is generally the first time running the program will appear, restart myRIO re-start the program no problem.
The second problem is running in the process, often appear to write TCP data error, error 3970001, directly lead to the program to stop running, restart the program, there will be the first listener problem.
I would like to ask these two questions how to solve, thank you very grateful
