NI LabVIEW,CVI,数据采集等产品讨论区
取消
显示结果
搜索替代
您的意思是:
PCI6143触发和数字输出
请问PCI6143的Digital trigger和Digital output不能一起用吗 现在情况是这样的,我用8路数字输出控制模拟开关,可以正常输出高低电平。 但是我用PFI0作为触发源,触发数字输出,数字输出无法输出高电平,且程序运行报错200452
0 项奖励
1 条消息(共 2 条)
1,980 次查看
Hello Djun,
Error -200452 may occur because of unsupported property have been used or incompatibility between the task/channel configuration and the property node you have chosen.
I recommend you to look at this papers for better understanding.
http://www.ni.com/tutorial/5338/en/
http://zone.ni.com/reference/en-XX/help/370471AM-01/cdaqmxsupp/pci-6143/
http://zone.ni.com/reference/en-XX/help/370471AM-01/mxcprop/attr2985/
http://zone.ni.com/reference/en-XX/help/370471AM-01/mxcprop/func2985/
__________________________________________
The best way to thank, is to give KUDOS
0 项奖励
2 条消息(共 2 条)
1,791 次查看
