01-25-2010 08:44 PM - edited 06-16-2017 12:52 AM
Description:
The LabVIEW 2009-2017 Advanced Signal Processing Toolkit (64-bit) provides VIs for time frequency analysis, time series analysis, and wavelet analysis. You can process larger data sets with the Advanced Signal Processing Toolkit (64-bit) than with the 32-bit version, if more memory is present. You must activate a valid NI LabVIEW 2009-2017 (32-bit) Advanced Signal Processing Toolkit license in order to activate your copy of the Advanced Signal Processing Toolkit (64-bit) after the 30-day evaluation period expires.
Software Requirements:
The computer you are using must meet the following minimum system requirements to run the Advanced Signal Processing Toolkit (64-bit):
1 NI software installs VC2015 Runtime and .NET 4.6.1. Windows 8.1 and Windows Server 2012 R2 require Microsoft updates to support these items. Refer to Microsoft KB2919442 and KB2919355 for more information about how to install these updates.
2 NI software is signed with a SHA-256 certificate. Windows 7 SP1, Windows Embedded Standard 7 SP1, and Windows Server 2008 R2 SP1 require Microsoft updates to support SHA-256. Refer to Microsoft KB3033929 for more information about how to install this security update.
Please feel free to ask questions here and provide feedback to NI R&D.
ZJ (Zhijun) Gu
01-25-2010 11:20 PM
Here are some simple examples that will work with ASPT 64-bit if memory is larger than 4GB. They will never succeed to run with ASPT 32-bit.
Time Frequency Analysis: STFTTest.vi
Time Series Analysis: MUSICTest.vi
Wavelet Analysis: DWTTest.vi
Larger data set can be supported if physical memory is large enough.
Mac Zhang
04-28-2010 09:03 AM
Results of tesing the 64-bit Advanced Signal Processing (ASP) toolkit Functions using the NDE Wave & Image Processor Software ( http://sine.ni.com/cs/app/doc/p/id/cs-11698 ).
Module | Operation based on initial testing |
Signal Wavelet Denoise | Working Fine |
Signal Wavelet MultiResolutionAnalysis & Reconstruction | Working Fine |
Signal Wavelet Detrend | Working Fine |
Image Wavelet MultiResolution Analysis & Reconstruction | Working Fine |
Image Wavelet Denoise | Working Fine |
Joint-Time Frequency | Working Fine |
All of the underlying functions from the ASP toolkit that support these functions appear to be working fine. I plan to test some of the newer features in the future including cepstrum and time series analysis as I incorporate these into my software.
Thank you NI!
Sincerely,
Don
05-17-2010 03:19 AM
Good results!
Feel free to post any other feedbacks!
ZJ Gu
08-08-2010 02:21 AM
IS IT POSSSIBLE TO USE LAB VIEW 8.6 FOR WAVLET NEURAL NETWORK ANALYSIS
08-08-2010 09:44 PM
What do you mean? Could you please tell more? In ASPT, we provide powerful wavelet tranform / application functions.
ZJ (Zhijun) Gu
08-10-2010 11:00 AM
my project is to identify forearm motions from emg signals,,,,, wavelet transform is used to filter out noise from emg signal and it ll provide the exact emg signal in the frequency domain,,,,,,,,,,,,,,,,,,if u have any other suggestions u can tell me regarding my project,,,,,,
thanks for ur reply,,,,,,,,,,,,,,,,,,
08-10-2010 08:07 PM
Then you can try Wavelet Denoise function in Advanced Signal Processing Toolkit.
ZJ (Zhijun) Gu
09-27-2010 04:12 PM
Is the toolkit compatible with the LV 2010 x64? It would be great if it is, as I am in the process of evaluating to see if I need to update my development machine...
Or is there a version compatible to 2010 coming out sometime in the near future?
09-27-2010 09:03 PM
Thanks for your request. We are now considering to support LV 2010 64bit. I will let you know if it is ready.
Thanks again!
ZJ (Zhijun) Gu
