05-26-2021 08:16 AM
Hi everybody,
I have a problem using DAQmx and NTP on a cRIO-9053.
When I install the DAQmx driver and NTP, the clock drifts.
I read somewhere that I have to choose between time synchronization modes for DAQmx (IEEE 1588, IEEE 802 or NTP).
My system can only use NTP. So I didn't install time sync services on my cRIO.
If I don't install DAQmx, everything is perfect. NTP synchronizes the time.
If I install DAQmx, the time drifts. More than one second per day.
Does someone have solved the problem ?
Thanks.
05-26-2021 03:31 PM
Hello, I believe there are two documents that can help explain this behavior and offer a few potential solutions:
In either case, I would be interested in hearing more about your application and what you are trying to accomplish so we (NI) can evaluate how we can better serve this type of use case. Please feel free to send me a message.
