NI Linux Real-Time Discussions
Connecting CRIO-9045 to SIEMENS SIMATIC HDMI (Display+TouchPanel)
I`m trying to run RT LV program on CRIO-9045 (only the CPU layer, not using the FPGA). If I connect keyboard and/or mouse (through  USB Type-C Splitter to USB PORT 2 on the CRIO Panel) the program works fine - good interaction between Mouse/Keyboard and the main VI`s Panel Controls.
If connect the USB cable  from the SIMATIC TouchPanel instead of the MOUSE, it`s stop to work (the program can run, but without Cursor and without the abillity of pressing Buttons and other Controls). I can touch the screen, and the CURSOR appears on wrong place.  In addition to this, even if I succeed to point at some LINUX ICONs (down the screen) or (try to) pressing on VI Panel Control, no reactions happen.
If I connect this SIMATIC (screen and touchpanel, through the HDMI and USB cables) to my PC (Laptop), it`s good. The TouchPanel work and behaving normally like as you touch Tablet Screen (circling the point you touch and selecting+Executing  the Program Icon you want).
Back to CRIO. I connect the mouse again, go through the LINUX settings, and activate the TouchPanel-Calib. Of course that with the Touchpanel bad interactions I can`t do this. So at least I use the mouse to do this Calibration (no use so it seems).
The SIMATIC HDMI is SIEMENS IFP1500 BASIC.
Labview 23 Q3 32-bits
Drivers: NI Compact RIO 23-Q4, Labview RT modules 23-Q1
Windows 10 64 bits (the LabVIEW Source environment)
CRIO LINUX OS DETAILS:
sh-5.1$ cat /etc/os-release
ID=nilrt
NAME="NI Linux Real-Time"
VERSION="9.4 (hardknott)"
VERSION_ID=9.4
PRETTY_NAME="NI Linux Real-Time 9.4 (hardknott)"
DISTRO_CODENAME="hardknott"
BUILD_ID="23.5.0f140-x64"
VERSION_CODENAME="hardknott"
sh-5.1$
Best regard , Shay
Message 1 of 1
(901 Views)
