04-07-2021 09:08 AM
Hi
I got a Custom Device which performs some CAN-Communications. The Custom Device runs for hours on end in Pharlap. I made a distribution for LinuxRT, at first the custom device seems to run correcty but after a while on of the Controller's (PXIe8840eQC) cores jump to 100% and the PXI responds no more.
In Phalap the load is kinda stable, in Linux the load jumps all over the place.
does anyone know how can I avoid this behaviour?
I know the post is a bit general but i can not post the CD. Maybe there are some considerations for the linuxRT Programming that differ from Pharlap?
-A
05-03-2021 03:07 PM
Is this in LabVIEW? I'd try and run in the development environment to see when the CPU goes to 100%. Yes, there are some considerations. For example, if you were opening a file that's at a different path in Linux, then that error could make a function that normally waits patiently (eg dequeue) immediately return an error which might use 100% of the CPU
05-05-2021 01:45 AM
Yes the implementation is in LabVIEW.
I discoverd, that the problem was, that too many of my VIs had high priority. I set most of the VIs to normal priority and the problem is now gone.
