NI Linux Real-Time Discussions
Error code 65700 occurred during engine initialization preventing execution
I have inherited a rather large project which had several issues that lead to some instability. The first issue resolution was to move the SVE to the real-time target and off the Windows PC. I have been using RT and FPGA for years and I am very comfortable with setting up and deploying projects. However this project uses DCAF to write to the Linux shared memory as a majority to this deployment runs on C code built years ago.
None of the hardware has changed, none of the software has changed, none of the I/O mapping has changed. The current DCAF configuration file is mapped to an alias called "sve_host" with an entry in the /etc/hosts file for the Windows PC hosting the SVE. To keep things super simple I updated the /etc/hosts/ file to add the alias "sve_host" tot he localhost alias for 127.0.0.1. I tried this approach to eliminate the need to edit close to a hundred variables in the configuration file.
I have rebuilt the project, deployed the variables, deployed the DCAF configuration and I get the following error in the /var/log/messages file, but cannot find any supporting documentation.
2021-02-08T17:00:35.900+00:00 NI-cRIO-9030-01E017D7 avahi-daemon[2779]: Service "NI-cRIO-9030-01E017D7" (/services/ssh.service) successfully established.
2021-02-08T17:00:35.901+00:00 NI-cRIO-9030-01E017D7 avahi-daemon[2779]: Service "NI-cRIO-9030-01E017D7" (/services/sftp-ssh.service) successfully established.
2021-02-08T17:00:39.056+00:00 NI-cRIO-9030-01E017D7 avahi-daemon[2779]: Joining mDNS multicast group on interface eth0.IPv4 with address 10.0.0.54.
2021-02-08T17:00:39.056+00:00 NI-cRIO-9030-01E017D7 avahi-daemon[2779]: New relevant interface eth0.IPv4 for mDNS.
2021-02-08T17:00:39.056+00:00 NI-cRIO-9030-01E017D7 avahi-daemon[2779]: Registering new address record for 10.0.0.54 on eth0.IPv4.
2021-02-08T17:00:39.285+00:00 NI-cRIO-9030-01E017D7 ifplugd(eth0): exit code: 0
2021-02-08T17:00:39.449+00:00 NI-cRIO-9030-01E017D7 /usr/local/natinst/bin/nirtmdnsd[3165]: starting
2021-02-08T17:00:40.998+00:00 NI-cRIO-9030-01E017D7 nitsmd[3519]: Starting TimeSync daemon...
2021-02-08T17:00:41.007+00:00 NI-cRIO-9030-01E017D7 nitsmd[3519]: Starting TimeSync RPC server...
2021-02-08T17:00:41.008+00:00 NI-cRIO-9030-01E017D7 nitsmd[3519]: Successfully started TimeSync RPC server.
2021-02-08T17:00:41.009+00:00 NI-cRIO-9030-01E017D7 nitsmd[3519]: TimeSync daemon running.
2021-02-08T17:00:57.573+00:00 NI-cRIO-9030-01E017D7 DCAF::Module::Scan Engine: Error code 65700 occurred during engine initialization preventing execution.
2021-02-08T17:00:57.573+00:00 NI-cRIO-9030-01E017D7 Error details:
2021-02-08T17:00:57.573+00:00 NI-cRIO-9030-01E017D7 Error 65700 occurred at Property Node in Scan Engine runtime.lvclass:populate_index.vi:4840001->Scan Engine runtime.lvclass:init.vi->TBM module execution interface.lvclass:init wrapper.vi->Standard Engine Runtime.lvclass:Initialize Module.vi->Standard Engine Runtime.lvclass:Initialize From Config.vi->Standard Engine Runtime.lvclass:Initialize.vi->DCAF Execution Service.lvlib:DCAF Execution Service.vi->cRIO Main.vi
2021-02-08T17:00:57.573+00:00 NI-cRIO-9030-01E017D7 Possible reason(s):
2021-02-08T17:00:57.573+00:00 NI-cRIO-9030-01E017D7 CompactRIO: Unable to communicate with the module. Reinsert the module and check connections.
2021-02-08T17:00:57.743+00:00 NI-cRIO-9030-01E017D7 DCAF::Engine::Standard Engine Runtime.lvclass: Started
2021-02-08T17:02:16.611+00:00 NI-cRIO-9030-01E017D7 kernel: [ 112.666792] random: nonblocking pool is initialized
Doug Ferguson
www.southerndaqsolutions.com
(1,417 Views)
Accepted by DougFerguson
You could see if anyone in the DCAF forum can help with this issue:
https://forums.ni.com/t5/Distributed-Control-Automation/gh-p/5235?profile.language=en
The errors seem related to the DCAF engine.
David C
(1,387 Views)
