NI Linux Real-Time Discussions
NI Linux RT Secret Store
I was trying to setup a method for securely storing secrets on these targets. I was able to install libsecret with "opkg install libsecret". This installed successfully. From there I tried to store a simple secret using "secret-tool store --label='mypassword' password secretpassword". I initially was getting a "Cannot autolaunch D-Bus without X11 $DISPLAY" error back. I ran the command "export $(dbus-launch)" and now when I run that same command I get this message back "The name org.freedesktop.secrets was not provided by any .service files". Is there any advice on getting libsecret working on NI Linux RT? Or is there a different tool out there that people have gotten working for storing secrets? I think if I had to I could use sqlite and encrypt the databse or use GnuPG to encrypt a text file but just curious if there was a more purpose built tool for storing and retriveing secrets securely (ideally over a terminal) that anyone has gotten working.
(136 Views)
Accepted by topic author Cannon_Controls
I'm not an expert on these guts but the fact it is asking for a .service file suggests it is expecting a SystemD init system but LinuxRT is still SysV. I don't know if that could be a mistake in the build that is installed with Opkg or a fundamental limitation in libsecret.
I've seen a few things that suggest the secret-tool may depend on gnome-keyring which is what provides the DBus service (such as https://bbs.archlinux.org/viewtopic.php?id=239198 and listed as a runtime dependency in https://www.linuxfromscratch.org/blfs/view/12.1-systemd/gnome/libsecret.html). This is obviously part of the gnome desktop environment so I don't know how easy it would be to get on LinuxRT.
James Mc
CLA and cRIO Fanatic
My writings on LabVIEW Development are at devs.wiresmithtech.com
(116 Views)
Gotcha, that is very helpful. I'll maybe forego this and see if I can find a similar tool out there that will be more compatible. I appreciate you looking into this!
(106 Views)
