NI Linux Real-Time Discussions
PySide2 installation
I have to run a python script using signal/slot of QT (this script communicate with a labview vi)
I have installed https://repo.anaconda.com/miniconda/Miniconda3-py37_4.10.3-Linux_x86_64.sh to have a python installation.
Then I tried to install PySide2: pip install PySide2
here all is ok
but when I run a python script using PySide2 as import I get:
"Got keys from plugin meta data ("xcb") QFactoryLoader::QFactoryLoader() checking directory path "/home/admin/miniconda3/bin/platforms" ... Cannot load library /home/admin/miniconda3/lib/python3.7/site-packages/PySide2/Qt/plugins/platforms/libqxcb.so: (libxcb-icccm.so.4: cannot open shared object file: No such file or directory) QLibraryPrivate::loadPlugin failed on "/home/admin/miniconda3/lib/python3.7/site-packages/PySide2/Qt/plugins/platforms/libqxcb.so" : "Cannot load library /home/admin/miniconda3/lib/python3.7/site-packages/PySide2/Qt/plugins/platforms/libqxcb.so: (libxcb-icccm.so.4: cannot open shared object file: No such file or directory)" qt.qpa.plugin: Could not load the Qt platform plugin "xcb" in "" even though it was found. This application failed to start because no Qt platform plugin could be initialized. Reinstalling the application may fix this problem." error.
It seems libqxcb.so try to use libxcb-iccc.so.4... "
Can someone help me how I can solve my problem ?
Maybe I need libxcb-iccc.so.4 ? If yes, how to get it ? which command  opkg ?
uname -a : Linux NI-cRIO-9040-01D92C83 4.14.87-rt49-cg-7.1.0f0-x64-41 #1 SMP PREEMPT RT Mon Jun 3 21:14:56 UTC 2019 x86_64 x86_64 x86_64 GNU/Linux
Thanks a lot
Jerome
Message 1 of 1
(925 Views)
