NI Linux Real-Time Discussions
Reboot button cRIO-903x in panel Embedded UI
Hello;
I want to put a button in the panel of the embedded UI to allow the user to reboot the system.
I Get restart from the command line as an administrator, but want the lvuser could reboot the system with a button on the panel.
I'm able to reboot the cRIO using the shell as administratos, but  I want th lvuser coul reboot the system with a button on the panel.
Is there any way to do it?
Image and video hosting by TinyPic
<script type="text/javascript" async src="//cdn.youracclaim.com/assets/utilities/embed.js"></script>
(4,063 Views)
What version of the software stack are you using (from MAX's "Operating System" entry or by running the command "uname -a", both while the target has software installed)?
I think the issue you're running into is that the "reboot" command is not on a normal user's path, you need to call out a direct path to /sbin/reboot. This is a symlink to a symlink to a binary (/sbin/reboot -> /sbin/reboot.sysvinit -> /sbin/halt.sysvinit).
The binary that it eventually points to has a special permission bit set: the setuid bit. This special bit tells the kernel to look at the ownership of the file and use that for the capabilities for running the binary (e.g. run the binary as if the owner of the binary file is running the binary). This binary is owned by admin/root.
I did a quick check on a target sitting on my desk by using the su command to become the lvuser user, calling /sbin/reboot directly, and it works as expected. I am not really in a convenient place to check if calling the same binary from LV works as well, but if not you should report that.
(3,819 Views)
Thanks BradM
Calling /sbin/reboot works fine.
(3,819 Views)
Accepted by anderg
Hi anderg,
There's also a restart VI that should work as well, you just have to pass in a session:
(3,819 Views)
SAL9000,
I blame my answer on a lack of coffee. It did directly answer the question, but is not the best answer.
andberg,
I certainly recommend using the actual LV functionality, not the SystemExec calling the function, as I suggested.
(3,819 Views)
Is there an easy way to call this from the Xfce desktop (maybe a link to a batch file or similar) or menu or taskbar?
DQMH® (Developer Experience that makes you smile )
(2,717 Views)
Hey joerg.hampel,
I did a quick test and you can create a file that calls /sbin/reboot and call it from a launcher on the XFCE desktop.
For example, I created a file /home/lvuser/restart with the following.
#!/bin/bash
/sbin/reboot
Then, I called the file restart from a launcher after creating a new panel on the desktop. This worked and rebooted the target.
Andy
PSE
(2,702 Views)
