09-13-2019 06:21 PM - edited 09-13-2019 06:24 PM
I just wanted to share a basic how-to for remotely updating a RIO using only SSH and bash commands. These have been put together from various snippets here in the discussions, and from my own experimenting.
These may be used to develop a bash script or an Ansible playbook to update and manage your targets. If you use Ansible's raw module then you may even avoid having to install Python on the targets!
Creating an image of current system:
/etc/init.d/nisetbootmode force-install "just gettin' an image" && reboot
nisystemimage get -x tgz -f some_image_name.tar.gz
This will take a few minutes to complete, and will complete silently. After it is done your image file should show up in your current folder (I usually just use the home folder).
scp admin@192.168.0.5:~/some_image_name.tar.gz desired/save/path/There are multiple ways to copy a file from a target to your PC, this is just my own preference!
/etc/init.d/nisetbootmode force-runtime && reboot
Applying a system image:
NOTE: Everything in the runtime OS will be overwritten, including the system password!
/etc/init.d/nisetbootmode force-install "just setting an image" && reboot
scp path/to/image/some_image_name.tar.gz admin@192.168.0.5:~There are multiple ways to copy a file to your target, this is just my own preference!
nisystemimage set -x tgz -f some_image_name.tar.gz -p preserve -s preserveThis usually finishes within a minute or two. I usually get errors like "/dev/sda4 is not encrypted (not a luks device)" or "nilrtdiskcrypt_canopen: No such file or directory". Everything seems to work just fine despite these messages. Both the primary and secondary network adapter settings are preserved here.
nirtcfg --set section=SYSTEMSETTINGS,token=sshd.enabled,value=True
Updating the firmware/safe-mode OS:
scp path/to/firmware/some_firmware.cfg admin@192.168.0.5:~There are multiple ways to copy a file to your target, this is just my own preference!
niinstallsafemode some_firmware.cfgThis may take a minute or two and usually gives "not a luks device" errors, but this is OK (maybe this only applies to those with encrypted disks?).
nisafemodeversion
Some notes:
09-18-2019 11:46 PM
This is about the best thing I've ever seen posted on this forum. Thank you for finding this and documenting it!
We use Linux as our development environment and thus dealing with Windows and MAX to set up the NI Linux RT targets is awful. We have much of it done in ansible but didn't know how to do firmware or images so that remained in MAX and RAD. This fills that gap! We can probably get rid of windows and MAX!
For PXI I'm also going to cache all the opkg files into our ansible repo so we can just install those without ever using MAX. I havent looked at if opkg based drivers are available for crio yet tho. (we have crios on 2018 and recently started testing PXI on 2019).
09-19-2019 12:44 PM
Several of us internal NI developers are absolutely chuffed at this thread. Thank you.
Also thanks for demonstrating that some customers are using ansible. I do feel obliged to ask how tied you are to ansible, because SystemLink is all salt-based, and you are generally going to have a smoother supportability experience if you can hitch your sails to that instead.
Applying a system image:NOTE: Everything in the runtime OS will be overwritten, including the system password!
Two caveats:
Spoiler
- Login via SSH again once target has rebooted.
- Create the image file:
nisystemimage get -x tgz -f some_image_name.tar.gz- Copy image file to your host PC via SCP. From a terminal on your host PC run:
This will fail if the image is too large.
ssh admin@target "nisystemimage get -x tgz" > image.tar.gzAnd do the likewise thing on restore. The main drawback with this approach is that if the file transfer fails, your runmode is hosed; but since you're already in safemode, you should be able to recover from this.
The niinstallsafemode and nisystemimage commands seem to be new with LV 2019, so you may not have these tools installed on your target.
AFAIK, nisystemimage and niinstallsafemode have existed since LV 2014. So I'm not sure how you came to this conclusion.
Testing was done using cRIO-9086 and 9047 targets running NI Linux Real-Time 4.14.87-rt49-cg-7.0.0f0.
The general nisystemimage process should continue to work, IIRC, for the vast majority of NI Linux RT controllers which use the "old" (non-opkg-based) MAX install process. For opkg-based installs, which includes PXI and SystemLink, it might work, but is not tested and is discouraged — configuration management is meant to be done through SystemLink and/or salt. It definitely won't work at all for NXG.
Offhand, I am aware of no proscriptions against niinstallsafemode, except the usual ones (it's completely unsupported when used directly; if it fails you will need to call NI support to iron things out; etc.)
These and other command line tools are located in /usr/local/natinst/bin/. These tools also have little-to-no documentation. This combined with little mention of them in the white papers tells me that they may be unsupported! Use caution!
You can say that again!
An image that was created with RAD can be applied using nisystemimage. You just have to unzip the *.lvappimg file and extract the *.tar.gz file within it.
Yes — with the caveats mentioned above about how NI System Configuration does its own thing about sensitive content. IIRC, the principal side effect of applying a system image directly is that system passwords will probably not be updated.
09-19-2019 12:50 PM
I think we would be interested in using system link instead of ansible (since system link is supported first class by NI) if it could be run on a linux server
09-23-2019 05:12 PM
@rtollert, huge thanks for providing more info and the caveats about these functions.
I explored the option of using SystemLink in the past, it looks like a very promising tool and I personally would have preferred to use it. The decision to go with ansible-based management was primarily driven by conformity. The IT department here is familiar with ansible and already had SSH ports open in the remote networks for existing Unix boxes.
I did not find these tools on some of our 9068 systems running 6.0.0 and 6.5.0 so I assumed it was a 2019 addition. Perhaps they're located in a different directory?
Thanks again for the info.
09-22-2020 10:25 PM
I just want to change my NI PXIe 8840 QC from windows to Linux RT. And the local sales not support for this application, just give me some documents.
Now,I changed the boot and the get PXI into Linux safemode.
But, when I formdisk from the MAX, the MAX crashed!!
I can connected PXI by putty.
If I can use the nisystemimage command to install the image files??
And I wander if the \Program File(x86)\National Instruments\RT Image\PXI System Image\19.0.0\systemlink-linux-x64-dkms.tar is the image file?
Hope for your apply! Thanks very much!
09-22-2020
10:52 PM
- last edited on
07-18-2024
09:44 AM
by
Content Cleaner
This reply is not pertinent to the original post — that was about advanced control of the system imaging process, while the basic functionality is not working right for you — but I might be able to give you some pointers.
Two things. First of all, if MAX crashes there, that is a problem (and probably a recent regression), and NI support should be informed about it. Second (and more importantly) — did you simply switch the BIOS boot setting to Safe Mode? If so, that's insufficient, you need to follow the instructions in e.g. https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4CsCAI&l=en-US to boot off of a USB recovery key to refresh the disk layout.
I'm assuming you mean ssh. It would not overly surprise me if you were able to ssh in without a working Linux filesystem, but it would surprise me a little. Uploading the contents of /var/log/messages here would not be a bad idea for the purposes of investigation.
No, none of the above things are going to help you at all. You need to focus on getting MAX to think happy thoughts. 🙂
09-23-2020
01:56 AM
- last edited on
07-18-2024
09:44 AM
by
Content Cleaner
Thanks very much for your reply and advices!!
I have followed the steps in the instructions https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4CsCAI&l=en-US
And I cat /var/log/messages as in the attachment.
Wish you could help me to find something wrong with my system!
09-23-2020 10:34 AM
Sorry, I'm out of easy suggestions, I'd call support.
09-24-2020 03:08 AM
By monitoring the windows log on computer management of the PC installed MAX.
I found a Framework problem "System.InvalidOperationException".
Maybe this is the reason MAX crash.
I will try to repair this problem, and try again.
I'm a newer for Linux, wish me good luck!
Thank you very much for your help!
