NI Linux Real-Time Discussions
Trouble mounting on startup via fstab
I previously modified fstab to mount an external disk to a CompactRio, and this works well.
/dev/sda1      /x            ext3       defaults         0  2
I want to add a bind mount that also is available after startup. To do so, I added the following after the above:
/x/data  /sftp/share/mydata  none       defaults,bind    0  0
If I run `mount -a`, the bind mount becomes available. However, if I reboot the system, the bind mount is not automatically mounted.
After some research, I see that the mounts are setup by the /etc/init.d/mountall.sh script:
mount -at nonfs,nosmbfs,noncpfs 2>/dev/null
I would expect this to mount the bindfs, but it unfortunately appears not to be doing so.
Any help is appreciated!
(1,087 Views)
methinks mountall will race badly against udev. You should write a custom udev rule to do what you want here.
Otherwise, I would be very curious what would happen if you removed
-t nonfs,nosmbfs,noncpfs
It's possible that some improvement could be made here; an odd util-linux mount behavior could be getting tickled.
Adding `-v` to the mount options may also be helpful in diagnosing this (in conjunction with bootup logs).
(1,052 Views)
