NI Linux Real-Time Discussions
USB Power Management on Linux RT
After a long period of inactive use over Christmas a LinuxRT application is hanging. I have a working theory that the USB device we talk to (through RAW) has entered a sleep state and isn't waking.
To look into this theory I've been looking for the /power folder under the devices as described in https://www.kernel.org/doc/html/v4.13/driver-api/usb/power-management.html but it doesn't seem to exist.
I'm thinking the NI kernel may have the USB power management disabled which would explain the absence, is this correct?
James Mc
CLA and cRIO Fanatic
My writings on LabVIEW Development are at devs.wiresmithtech.com
(2,073 Views)
Yes you are correct, power management is disabled in the kernel configuration for NI LinuxRT. This is done to improve the real-time characteristics (waking up from sleep  states can induce significant latencies).
You can verify this by running something like this in a serial/ssh console:
admin@lepton:~# zcat /proc/config.gz | grep CONFIG_PM
# CONFIG_PM is not set
If you still have the target in a hung state it would be useful to look a the kernel log - it might give you clues on what's going on with the USB device. You can get the log by running the 'dmesg' command in a shell or by looking at the '/var/log/messages' log file (the log file will contain non-kernel messages too so you'll have to search around).
(2,020 Views)
Awesome that's great to know.
We found the issue in the end to be a combination of small quirks in the LabVIEW app so we have it running again now.
James Mc
(2,005 Views)
