11-02-2015 10:18 AM
Use the branch that corresponds to the release that you're using, and follow the instructions in the github branch (e.g. for 2015 release: https://github.com/ni/linux/blob/nilrt_pub/15.0/3.14/README)
11-02-2015 10:28 AM
In which path I have to run "make menuconfig"? I tryed in /linux-nilrt_pub-15.0-3.14/ but the error on "ncurses-dev" module occurs even if I have installed the "libncurses5" pkg.
11-02-2015 10:37 AM
solved for menuconfig.. I have used:
opkg install ncurses-dev
I'll try to activate the HIDRAW and testing the touchscreen
11-03-2015 03:07 PM
I have same problem.
I can move the 'mouse pointer' but not click.
Did you solve it??
11-03-2015 03:45 PM
m-power, Seyong,
It would be beneficial to know what displays you guys are using
11-04-2015 12:36 AM
I'm using touch monitor made by INDUSCOM in Korea.
I think that is same with m-power's problem exactly.
(1) xinput list
bash-4.2# xinput --list
� Virtual core pointer id=2 [master pointer (3)]
� ��� Virtual core XTEST pointer id=4 [slave pointer (2)]
� ��� Logitech USB Optical Mouse id=14 [slave pointer (2)]
� ��� eGalax Inc. USB TouchController Pen id=10 [slave pointer (2)]
� ��� eGalax Inc. USB TouchController id=11 [slave pointer (2)]
� Virtual core keyboard id=3 [master keyboard (2)]
��� Virtual core XTEST keyboard id=5 [slave keyboard (3)]
��� Power Button id=6 [slave keyboard (3)]
��� Video Bus id=7 [slave keyboard (3)]
��� Power Button id=8 [slave keyboard (3)]
��� Sleep Button id=9 [slave keyboard (3)]
��� Logitech USB Keyboard id=12 [slave keyboard (3)]
��� Logitech USB Keyboard id=13 [slave keyboard (3)]
(2) optical mouse test
bash-4.2# xinput test 14
motion a[0]=1017 a[1]=1002
motion a[0]=1019
motion a[0]=1021 a[1]=1000
motion a[0]=1022
motion a[0]=1023 a[1]=999
motion a[0]=1024
motion a[0]=1025
motion a[0]=1026 a[1]=998
motion a[0]=1029
motion a[0]=1030
motion a[0]=1029
motion a[0]=1027 a[1]=999
motion a[0]=1025 a[1]=1001
motion a[0]=1023 a[1]=1002
motion a[0]=1020
^Z
[2]+ Stopped xinput test 14
(3) eGalax Inc. USB TouchController test
bash-4.2# xinput test 11
^Z //nothing !!
[3]+ Stopped xinput test 11
bash-4.2#
(4) bash-4.2# cat /proc/bus/input/devices
I: Bus=0003 Vendor=0eef Product=0001 Version=0210
N: Name="eGalax Inc. USB TouchController Pen"
P: Phys=usb-0000:00:14.0-3/input0
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input10
U: Uniq=
H: Handlers=mouse1 event7
B: PROP=0
B: EV=1b
B: KEY=c01 0 0 0 0 0
B: ABS=3
B: MSC=10
N: Name="eGalax Inc. USB TouchController"
S: Sysfs=/devices/pci0000:00/0000:00:14.0/usb1/1-3/1-3:1.0/input/input11
U: Uniq=
H: Handlers=mouse2 event8
B: PROP=2
B: EV=b
B: KEY=400 0 0 0 0 0
B: ABS=a60800000000003
(5) evtest ( refer to : https://decibel.ni.com/content/message/115075_
bash-4.2# evtest |
No device specified, trying to scan all of /dev/input/event*
Available devices:
/dev/input/event0: | nilrt:user1:uservisible=1:states=(0,1) |
/dev/input/event1: | Logitech USB Keyboard |
/dev/input/event2: | Logitech USB Keyboard |
/dev/input/event3: | Logitech USB Optical Mouse |
/dev/input/event4: | Power Button |
/dev/input/event5: | Sleep Button |
/dev/input/event6: | Power Button |
/dev/input/event7: | eGalax Inc. USB TouchController Pen |
/dev/input/event8: | eGalax Inc. USB TouchController |
/dev/input/event9: | Video Bus |
Select the device event number [0-9]: 8
Input driver version is 1.0.1
Input device ID: bus 0x3 vendor 0xeef product 0x1 version 0x210
Input device name: "eGalax Inc. USB TouchController"
Supported events:
Event type 0 (EV_SYN)
Event type 1 (EV_KEY)
Event code 330 (BTN_TOUCH) |
Event type 3 (EV_ABS)
Event code 0 (ABS_X) | ||
Value 1838 | ||
Min | 0 | |
Max | 4095 | |
Event code 1 (ABS_Y) | ||
Value 1990 | ||
Min | 0 | |
Max | 4095 | |
Event code 47 (ABS_MT_SLOT) | ||
Value | 0 | |
Min | 0 | |
Max | 7 | |
Event code 53 (ABS_MT_POSITION_X) | ||
Value | 0 | |
Min | 0 | |
Max | 4095 | |
Event code 54 (ABS_MT_POSITION_Y) | ||
Value | 0 | |
Min | 0 | |
Max | 4095 | |
Event code 57 (ABS_MT_TRACKING_ID) | ||
Value | 0 | |
Min | 0 | |
Max | 65535 | |
Event code 59 (ABS_MT_DISTANCE) | ||
Value | 0 | |
Min | 0 | |
Max | 1 |
Properties:
Property type 1 (INPUT_PROP_DIRECT)
Testing ... (interrupt to exit)
Event: time 1446790600.874460, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 3220
Event: time 1446790600.874460, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 2692
Event: time 1446790600.874460, type 3 (EV_ABS), code 59 (ABS_MT_DISTANCE), value 0
Event: time 1446790600.874460, type 3 (EV_ABS), code 0 (ABS_X), value 3220
Event: time 1446790600.874460, type 3 (EV_ABS), code 1 (ABS_Y), value 2692
Event: time 1446790600.874460, -------------- SYN_REPORT ------------
Event: time 1446790600.878456, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 3218
Event: time 1446790600.878456, type 3 (EV_ABS), code 0 (ABS_X), value 3218
Event: time 1446790600.878456, -------------- SYN_REPORT ------------
Event: time 1446790600.890463, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 3216
Event: time 1446790600.890463, type 3 (EV_ABS), code 0 (ABS_X), value 3216
Event: time 1446790600.890463, -------------- SYN_REPORT ------------
Event: time 1446790600.900463, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 3214
Event: time 1446790600.900463, type 3 (EV_ABS), code 0 (ABS_X), value 3214
Event: time 1446790600.900463, -------------- SYN_REPORT ------------
Event: time 1446790600.906461, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 3212
Event: time 1446790600.906461, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 2690
Event: time 1446790600.906461, type 3 (EV_ABS), code 0 (ABS_X), value 3212
Event: time 1446790600.906461, type 3 (EV_ABS), code 1 (ABS_Y), value 2690
Event: time 1446790600.906461, -------------- SYN_REPORT ------------
Event: time 1446790600.910479, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 3210
Event: time 1446790600.910479, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 2686
Event: time 1446790600.910479, type 3 (EV_ABS), code 0 (ABS_X), value 3210
Event: time 1446790600.910479, type 3 (EV_ABS), code 1 (ABS_Y), value 2686
Event: time 1446790600.910479, -------------- SYN_REPORT ------------
Event: time 1446790600.916475, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 3208
Event: time 1446790600.916475, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 2682
Event: time 1446790600.916475, type 3 (EV_ABS), code 0 (ABS_X), value 3208
Event: time 1446790600.916475, type 3 (EV_ABS), code 1 (ABS_Y), value 2682
Event: time 1446790600.916475, -------------- SYN_REPORT ------------
Event: time 1446790600.922448, type 3 (EV_ABS), code 53 (ABS_MT_POSITION_X), value 3206
Event: time 1446790600.922448, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 2678
Event: time 1446790600.922448, type 3 (EV_ABS), code 0 (ABS_X), value 3206
Event: time 1446790600.922448, type 3 (EV_ABS), code 1 (ABS_Y), value 2678
Event: time 1446790600.922448, -------------- SYN_REPORT ------------
Event: time 1446790600.926450, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 2672
Event: time 1446790600.926450, type 3 (EV_ABS), code 1 (ABS_Y), value 2672
Event: time 1446790600.926450, -------------- SYN_REPORT ------------
Event: time 1446790600.932469, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 2666
Event: time 1446790600.932469, type 3 (EV_ABS), code 1 (ABS_Y), value 2666
Event: time 1446790600.932469, -------------- SYN_REPORT ------------
Event: time 1446790600.938460, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 2658
Event: time 1446790600.938460, type 3 (EV_ABS), code 1 (ABS_Y), value 2658
Event: time 1446790600.938460, -------------- SYN_REPORT ------------
Event: time 1446790600.944479, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 2650
Event: time 1446790600.944479, type 3 (EV_ABS), code 1 (ABS_Y), value 2650
Event: time 1446790600.944479, -------------- SYN_REPORT ------------
Event: time 1446790600.950469, type 3 (EV_ABS), code 54 (ABS_MT_POSITION_Y), value 2640
Event: time 1446790600.950469, type 3 (EV_ABS), code 1 (ABS_Y), value 2640
11-05-2015 08:36 AM
I'm using a Panel touchesceen using Egalax driver.
I'm tryng to compile the kernel with the HIDRAW enabled in the menuconfig as suggested. I need to load the old configuration but there is no .config in the /boot or /usr/src/. Where can I find the configuration file?
For Seyong: I didn't solve.. work in progress
11-05-2015 08:59 AM
m-power, is the panel really from a company named "Panel"? Is that the model name? Can you find a model number on the device?
As for the kernel configuration, as I recall, you're building the kernel on the controller, is that correct? Basically, follow the instructions here (make sure to look at the branch that matches the version of the software you're using, look at the KERNEL_SOURCE file), but adjust for compiling on the target itself (e.g. don't set ARCH, don't set CROSS_COMPILE).
The configuration you should work from is already resident in the kernel itself: in the instructions when you make nati_x86_64_defconfig, you're copying the correct default configuration that NI uses for building the kernel to be used when you build or further configure the kernel.
11-05-2015 09:52 AM
Monitor I'm using is reported below
http://www.panel.it/eng/Products/Monitor/PMQ0xx-Series-(4_3-Format)/PMQ017
11-06-2015 08:32 AM
Hi BradM, is it possible to activate the hidraw module in the .config without downloading and compiling the kernel? I received the cRIO 9030 with the OS installed. Where can I fid the .config of the default XFCE version?
eGalax driver need 4 module to work: uinpup, evdev, hid_multotouch and HIDRAW. I'm able to compile and include by insmod the firs two modules; the third already is loaded by default but I'm not able to comiple/enable the HIDRAW.
can you help me with .config file and the relative path? The default /urs/src/ folder do not contains any config file (or it seems to me)
thanks again
