NI Package Manager (NIPM)
File Permission Changed by Package Process
I have a package that installs an UDL file under %ProgramData%. The original UDL file has user permissions set to Full Control. When the UDL file is installed as part of the package it ends up with user permissions of Read & execute/Read. My program (running as User) gets a file I/O error when trying to update this file. With the old school (not the future) installer file permissions could be set. Is it possible to do the same with Package Builder?
(1,582 Views)
Accepted by al_g
NI Package Builder does not carry any file permission or file attributes from the source file to the destination when installed. You must use a Custom Execute to operate on the file post install.
I believe that the following should work for you to create a custom execute which sets file permissions using the cacls.exe command on the target computer.
  1. In the Root property, select [System (32-bit)].
  2. Set the Executable Path to the name of the command prompt executable:
    cmd.exe
  3. In the Arguments property, provide the arguments needed to pass in a string to the command prompt and then run cacls.exe:
    /c cacls.exe ""%ProgramData%\<RestOfPathToFile>" /E /G "<UserName>":F"
  4. Click OK.
You should be able to use any of the Installation Target Roots for File Packages values with surrounding "%" characters as documented in the NI Package Manager help.
Scott Richardson
https://testeract.com
(1,555 Views)
Thank you. Your suggestions works, but after reading that Microsoft is deprecating cacls I modified the Custom Executes to use icacls. With icacls I was able to set permissions for my entire directory with a single command.
/c icacls.exe "%ProgramData%\...\Configuration Files" /grant:r Users:F /t /c
:r Replace attributes
:F Full Access
/t Changes ACLs of specified files in the current directory and all subdirectories.
/c Continues the operation despite any file errors
(1,519 Views)
