NI TestStand Idea Exchange
MimiKLM
Adapters: Exposure to WebServices
Status: Completed
TestStand now has a gRPC API that allows you to control & monitor TestStand from a remote machine in a OS & programming language agnostic way. We are also planning to provide web based interfaces in 2025-2026. Due to lack of any more info on the request, I'm marking this complete.
As in subject.
It would be good if TS would have an adapter which takls with WebServices.
2 Comments
JoshuaP
Can you expand on what functionality you would expect to be provided from the web service?
Are you just wanting to monitor the status of the tests? If so, I would suggest checking out SystemLink and its Test Module, which includes a plugin for TestStand that logs the current status and past results to the SystemLink Server and provides a web interface for reviewing the results and tracking the status.
HarshaBhushan
Status changed to: Completed
