I would like to ask to add named types support for TestStand array literals. The current behavior is described as follows:
Declares a one-dimensional array of numbers, strings, Boolean values, object references, or containers. If all elements are of the same type, the result array is an array of elements of that type. If all elements are not of the same type, the result array is an array of containers.
I would like it to be more or less like this:
Declares a one-dimensional array of numbers, strings, Boolean values, object references, containers, or named type. If all elements are of the same type, the result array is an array of elements of that type. If all elements are not of the same type, the result array is an array of containers.
The problem with the current implementation can be seen on the screen.
It is not a bug (BUG 1828580 to be more precise), it is a feature.
