Hi! Feature request that I hope is fairly simple to slide into the next rev. It's incredibly frustrating that a Combo Box's values (for a control wired to the connector pane of a VI) aren't selectable like Enums and Rings in the LabVIEW Adapter. Instead of seeing a drop down with selectable options, I have to open the VI, (open the control if it's a typedef), edit its values, then see what the values are, close that dialog out, close the VI, back to TestStand and put in the value. This is all so I can just hard code a value. This is crazy. I tested this out in 2019 64-bit, btw, so maybe it's available in later versions, if so, please let me know.
Thanks for your time.
