NI TestStand Idea Exchange
bienieck
Empty Array Literal
Status: New
Currently, there is no unambiguous solution for passing empty Array of X (where X is a different type than 64-bit Floating Point) as a sequence parameter. If we use {} it is assumed to be of type 64-bit Floating Point. To have an empty Array of Strings we can use ambigues Split("",""). I have no idea how to pass e.g. empty Array of Signed 64-bit Integer without creating empty variables.
It would useful to have Empty Array Literals of a particular type e.g.:
{} - default
{}i64 - for Signed 64-bit Integer
{}ui64 - for Unsigned 64-bit Integer
{}s - for String
{}b - for Boolean
{}r - for Object Reference
{}c - for Container
{}TYPE_NAME - for type definition where TYPE_NAME is type definition name; e.g. Path.
Michał Bieńkowski
CLA, CTA, CPI
1 Comment
Mr._Jim
Michał, I know it's been a while since you posted this, but it's nice to know that someone else has run into this.
I always thought, "There must be some way of doing this, but I just don't have the nuanced knowledge to accomplish it."
I also make empty "constant" locals, etc. to denote empty arrays, but it seems silly to have to do so.
