NI TestStand Idea Exchange
RaviShrigiri
Execution analyser similar to sequence analyser
Status: Duplicate
I'm closing this idea since there's a higher-voted similar one.
This execution analyser ( an option since it may slow down execution) will analyse the UUTGener executions and recomend user for improving the perfomance.
Few things that i can think of  is :
1) If a  debug DLL is running which if replaced will improve speed.
2) Check for memory leaks.
3) Generate list of steps which are logged many times ( example in loop which may not be requied to log)
4)List out steps which are taking long time to execute( say top 5)
5)List out steps whose execution time is inconsistent ( varies considerably from execution to execution
These are few of the things that i could think of.There maybe others.
2 Comments
warren_scott
It should have most all the functionality of sequence analyzer.  Largely because you sometimes want to run those same type of tests (from sequence analyzer) on the results cluster of an execution.  Reason being, sometimes you make changes to the code at run-time (dynamically calculate limits, loop settings, etc)
WireWeaver
Status changed to: Duplicate
