When I get called to look at an issue that has occurred with a test, the account logged into TestStand is typically a restricted user (i.e. Operator). Since the Operator account has very limited options, in order to really do much immediate troubleshooting I need to stop the test and re-run it in the Administrator account. At best this is inconvenient and inefficient if the spot the error occurred is late in the test. However, it is extremely frustrating when it's an intermittent run-time error and I can't do any real-time debug because Operator is logged in. The only real alternative I can think of (when the problem is intermittent) is to leave it logged in as Administrator so I can debug whenever it happens to occur. This is not really an acceptable practice in most cases.
It would be fantastic if there were an override that let's an Administrator provide the proper credentials to perform the desired task that would normally be off-limits to the Operator. The basic premise of this suggestion is similar to the functionality within Windows; if you try to connect to a secured location or perform a task that requires administrator privileges, a dialog box pops up asking you to enter authorized credentials.
I run into many situations where I wish this feature was present. The issue is not always within TestStand (could be a database connection issue, etc.), but it is TestStand that throws the error and in Operator mode the only option is "Run Cleanup". Significant time, effort, frustration, and efficiency could be saved if I could simply enter my credentials as an administrator to perform the tasks I need to do.
Regards
On an unrelated side note, I find it humorous that "TestStand" is considered a misspelled word when using the forum spell checker. 🙂
