The output messages are a good way of sending status messages from the test solution to the end user. However the control is not available as one of the controls that can be added to user interfaces.
Can this control be made available to be quickly added to a UI and linked to the execution view manager.
Also adding some kind of API interface to be able to capture these messages to a log file would remove the need to implement any custom logging mechanisms. If possible ability to open multiple file logs within the engine at the same time with each file given some kind of filter rules (for example Severity=”error” or ExecutionId=5). If logs had to be attributed to an execution ID then they could automatically be closed when the execution ended, otherwise the user would have to manually close each file which could get forgotten and TestStand end up with lots of open file references.
