If you add an array as a parameter to a sequence, you have the option of setting the array bounds. If you set the array bound to [1..3] for example and call this sequence and try to access the array element [3] there is an array out of bounds error. It looks like arrays as parameters with the size N are always seen as an array with the bounds [0..N-1]. Maybe it makes sense to change this to the expected behavior!
