Have you ever wanted to run a customizable batch file or executable after a CVI Application has been deployed? In my case I do. In my case, I want to automatically run a batch file that sets the Environment Paths in Windows of my executables and DLL's after the installation is completed. To make this work currently I am requiring the person who is installing the application to manually run a batch file to set up the Environment Paths in Windows. Potentially error prone if the paths are not set for my applications. My batch file would be written as: "Set Path <etc> from the command line prompt. CVI 2010 does not have this capability.
In older versions of CVI I think this feature existed but I do not know which CVI version National Instruments removed it from.
There may be other cases that I might want to run an executable(s) that sets up the application up in a default situation for first time use only.
I am sure there are other cases where other CVI Developers who would want this capability too.
In TestStand this feature exists in the "TestStand Deployment Utility" under the Custom Commands tab.
I'm declining this because it's not a TestStand idea.
