NI TestStand Idea Exchange
dotNet_to_LabW
Remove all unused variable in sequence file with single click
In order to keep file clean, sequence analyzer helps in finding "potentially unused variables". To delete such variables, each warning in sequence analyzer result has to be double clicked and then delete has to be pressed to finally remove that variable.
In many cases with large sequence file, there could be dozens of unused variables and in a single work-space there are dozens of .seq files.
Is it possible to provide a button or some option to remove all unused variables from a sequence file?
1 Comment
HarshaBhushan
Status changed to: Under Consideration
