It isn't uncommon to deploy customized TestStand options, such as search directories, on a deployment computer. It would be much easier to do this if the search directories in TestStand were stored in their own .ini file rather than in TestExec.ini. You can obviously set the search directories in TestExec.ini quickly using the built-in search directories GUI, but when distributing the TestExec.ini file to the deployment computer, you have to be careful that none of the other options contained in the file don't inadvertently cause problems when executing TestStand deployments. A separate .ini file for search directories would clearly remedy this situation.
