Some test sequencing tools incorporate the idea of configuration based variant handling, where you could define different test variants (e.g. testing at ambient temperature, hot, cold), each variant having it's own set of test limits.
Individual test steps can then be assigned to the previously defined variants. By chossing the desired test variant, the according steps will be executed without having the need to implement additional logic within the sequence.
