Currently, to export properties which are part of an array, such as the limits of a multiple numeric limit test, you have to specify each index of the array separately, like in the first screen shot, or else you get all of the raw XML, which is difficult to interpret and use.
This is both labor intensive and unituitive. . If instead we had the option to export the array with the "?" and have it parse the information out like in picture 1, it would be much simpler to use.
Kyle Mozdzyn
Applications Engineering
