If there's a way to do this already feel free to ignore this suggestion 🙂
I have a process that spawns N parallel measurements for a given DUT at one point during code, and then has a series of wait steps later, to collect all the results / errors / etc.
I have a reaonable timeout, with error generation enabled on the Wait steps as a safety mechanism in event a process hangs (rare, but not impossible). During normal execution these timeouts never trip, and all runs beautifully.
If I set a breakpoint/single-step my execution to troubleshoot one of the measurements during design/debug, often times it takes a while before I 'resume', and when I do, the timeout on the parallel wait immediately trips with error.
would there be some way to make the Wait step's timeout logic 'pause' while execution paused and 'resume' when sequence is executing normally? that way the error I'm trying to trap during debug won't get confused with an irrelevant error for 'you took too long'...
i know I can put conditional logic on the timeouts to discard the error if running inside the debugger, but it'd be cool if the step was just smarter in general
--Elaine R
