NI TestStand
A generic error occured in GDI+
Hi all,
Since today, I get an error when I launch SeqEdit 2019 : A generic error occured in GDI+.
I get this error message and SeqEdit closes.
I'm running TestStand (32bits) under Windows 10 (64 bits).
I found a similar issue but under Windows XP : http://digital.ni.com/public.nsf/allkb/2210EDE67847514986256FA5000282D3?OpenDocument
But not applicable for Windows 10.
Can someone help me or did someone get the same issue?
I'm totally blocked and I can't contine my development.
many thanks in advance for your help
(3,953 Views)
This is a pretty generic error that could have a lot of different root causes. Are you using TestStand environments or just launching the Sequence Editor like normal?
Either way, it might help to run the TestStand Version Selector to clean up your install:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019PfGSAU&l=en-US
Just select the version you have activated and hit Make Active (even if it's the same version, it will make a difference).
Cheers,
Ryan Curtis
Product Support Engineer
Automated Test Software R&D
(2,556 Views)
Accepted by maxmont
I recovery from a previous setup (thanks for virtualization).
And now it's working
To sum up, I di'nt manage to find the root cause of this issue.
(2,531 Views)
