10-14-2024 12:41 PM
I am using 32-bit VeriStand 2020 R3 being called from TestStand 2023 Q4 as well as 2024 Q4. I am trying to use the Get Script Parameter Values step but it is only able to read the Return Value in the VeriStand sequence which is quite limiting. Is this a bug in the ASAM XIL library, a limitation of VeriStand 2020, or a limitation of TestStand?
Is there another way to get more data back from VeriStand into TestStand that I am missing. I am also not trying to create 100's of User Channels that I would then use Framework Get Values step. We are able to set multiple parameters using Script Set Parameter Values so why can't we read multiple values back?
I am unable to upgrade the VeriStand version at this time due to the time and complexity involved.
10-16-2024 07:50 PM
You can use ASAM XIL Framework Steps to read/write all the channels defined in the System Definition file. Just select Create From VeriStand Project in the Framework Create step.
Reference: ASAM XIL Steps for NI TestStand
