Access a Station variable using Local Variable value
I'm trying to access the value of an Station Global depending on the value from a Local variable that will populate at runtime.
Eg. Instead of pointing to my Station Global in the following way: StationGlobals.Instrument1.Test
I want to use the value from a Local variable (Locals.Instrument) that will populate with the values 'Instrument1', Instrument2' or 'Instrument3' depending on the test.
Something like this:
StationGlobals.'Locals.Instrument'.Test
Is that something possible?
I hope my explanation is clear.
Thank you.
(869 Views)
Accepted by topic author CesM
You can do it in many ways. See attached example.
Michał Bieńkowski
CLA, CTA, CPI
(834 Views)
I really appreciate your help!
(824 Views)
