03-04-2022 01:51 PM
How would one use the TestStand API to access the step specific information while the sequence is running? I've been able to use the C# TS API to access the results, names, and types of each step once the sequence is finished, but I was hoping to be able to dynamically update the status of each step while the sequence is running. Is it possible to get the results of each step while the sequence is still running, or do you have to wait until the sequence is finished to access that information?
03-08-2022 01:36 PM
The following variable are populated with status as when the sequence is running :
1) locals.resultlist
2) Runstate.sequence.main
Hope this helps.
Ravi
