04-06-2016 07:03 AM
There is an application that uses TestStand user interface.
The main sequence starts and later a paralell sequence called and this is shown on the front panel of the user interface.
Is it possible to set which sequence's steps are shown on the user interface?
Such as 'active sequence' on the front panel?
Thanks in advance.
István
Solved! Go to Solution.
04-06-2016 08:22 AM
I think the easiest solution would be to disable tracing for the parallel step.
04-12-2016 05:08 AM
Hello pulidotech,
Thanks for your reply.
It is a good hint and it works.
The paralell sequence should be called as a New Thread not as a New Execution though.
