03-02-2010 03:42 PM
Hi.
I have a problem when installing my TestStand deployment made with the deployment utility in TestStand 4.2. My deployment distributes the standard full CVI UserInterface and makes a shortcut in the startup directory. During the installation process the UserInterface starts up with the following error:
Error in call to LoadPanel.
Parent Panel Handle: 0
UIR File Name: 3D Panel.uir
Panel Resource ID: 1
Error Code: -145
ActiveX
control not registered on this computer.
The same error comes again when the installation process is finished and the system starts up again after the reboot. The error disappears when the installer have finalised the installation.
I think the installer first registres the UserInterface as ActiveX server after reboot and this is the reason for my problen.
Is there anything i can change or add in my deployment in order to remove this error?
/Jacob
03-08-2010 04:17 AM
