09-09-2009 10:56 AM
I agree with clear the buffer, but I don't have a command to do that
I can, however send this commad twice as an action to clear the buffer, then send the third time and test the return
(I may be sending it 1 time too many on some boards, with a cost of 300ms, but I can live with that)
It's not as pretty, but it works
I assume that there is no way to embed a delay in the embedded step loop
Thanks All!
Ok, now onto teststand coding style:
Ray,
can you convince me that this loop to PASS functionality is for debug only?
After all, if I am in debug, I can select a step and loop on anything
In production use, I agree that the loop until pass will create LOTs of problems, and is a poor coding choice in general
Don't get me started on looping until it passes 5 times, hey there is something just wrong there
but, to syncronise, or flush a buffer, anything that is asynchonous in nature, It appears a valid choice to me, especially because it handles the error reporting gracefully, by just de selecting the record results for each iteration (anyone agree?)
Jeff
09-09-2009 12:00 PM
LOL!! 😄
I'm not going to try to convince anything to anyone, as everyone is entitled to an opinion.. 😄
Sometimes we have to do unpretty coding as a workaround.
There might be cases where the loop is necessary, such as the voting. For instance, you have a data acquisition system which unfortunately acquires noisy signals. You need to find some sort of signature within the signal and want to eliminate a fluke in the samples. You would then proceed with a vote, which means running the test at least 3 times and seeing if the signature could be detected twice. (ie: voteBetterThan > (#samples/2) + 1 )
There might be some other situations. If it was possible for you to implement the clear buffer of read once & discard the garbage communication within the software code, then I'd say that you should not use a loop to verify if there is a pass.
Your situation is a bit different and you are implementing it as a workaround. Not the best scenario, but it gets you out of a bind.. It's a controlled implementation that works for you. Let's keep it a that 😉
When you mention embedded code, are you referring to firmware? or embedded software (ie: VxWorks, etc)?
R
09-09-2009 12:20 PM
Teststand allows you to do the same things many different ways
I agree most of them are not ideal, some are good, 1 or 2 ways optimal
By embedded, I was referring to the looping tab on the step
If you choose CUSTOM, then you can mess with the looping logic using expressions
I was originally trying to get a delay in the loop, everything in 1 step
jeff
12-26-2017 11:54 AM
I used a custom loop to add a delay if the step failed until I got a pass to continue
Add this code to the "Loop Increment Expression"
RunState.Execution.WaitForEndEx(RunState.LoopNumPassed==0?100:0)
if it fails then add a delay of 100 ms.
02-26-2018 01:15 PM
Finally somebody actually answered the OPs question!
02-26-2024 11:17 PM
Could you help me? I don’t know why when i try to use your Loop Increment Expression, it appears that syntax error.
thanks!
02-27-2024 02:10 AM
Adding to a six year of thread that is already marked as solved is probably not the best way to get answers. Consider starting a new thread with a clear subject line.
