NI TestStand
Alternative Method to communicate with GUI (exe) and TestStand
Hi ,
Can anyone suggest an alternative method to communicate with TestStand and GUI(exe). Here I don't want to use user messages as I will be running the sequence from TestStand sequence executer.
I tried to use network published variables to transfer real time data (latest value) from LabVIEW exe to TestStand code module. Is there any better method to send commands from TestStand to LabVIEW.
-Vipin
(911 Views)
Accepted by Vipin@AMP
Use TCP to send and receive data between exe
Santhosh
Soliton Technologies
(901 Views)
You can also use TestStand synchronisation objects like queues or notifications. There are even LabVIEW wrapper's for it somewhere on the internet. It is possible to exchange information between processes using them.
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(869 Views)
