Batch step vs Batch sequence
Hi
In my hardware for best performance I have dedicated hardware for every site  , meaning that they can all run in parallel , but at the end they have to sync
TestStand has batch model , but I am not sure in TestStand , it sync after each step or it is possible to sync at the end of sequence ?  Definitely syncing at the end of each step is not useful for me and it waste a lot of time , because I have to always wait for slow DUT. Please help which model TestStand has as part of batch mode? is it batch step or batch sequence ?
Finally what is the model in NI STS ? is it batch step or batch sequence and is it configurable to switch between them?
(1,351 Views)
Batch model sync at the beginning and at the end.
NI STS uses Batch model at sequence level if there are no shared instruments between sites.
Santhosh
Soliton Technologies
(1,346 Views)
Thanks , this is great because I have no shared resource and they can fully run in parallel and sync at start and end of sequence
I don't have TestStand and STS right now , but I remember in batch model they used to sync after each step and then go to next step and this was the default setting . Do I have to change the setting to make it sequence sync instead of step sync ?
(1,323 Views)
Accepted by topic author ethen99
No, by default, the batch model sync only at the start of batch and end of the batch and not at every step unless you configured each step for synchronization.
Santhosh
(1,317 Views)
Thanks Santo, that is exactly what I want both in TS and STS. Sync at start and sync at end so all DUTs can run fully in parallel and sync at the end
(1,312 Views)
