CTD Exam Material Question of solution
I am a new TS user, I am prepare the CTD.
in the   CTD Sample Exam,  has this :
If the test fixture cannot be initialized
o Suppress all errors (but mark the test as an error)
o Record that it could not initialize the test fixture using an Additional Results step
 in the solution exam, I do not find  where  the sample *.seq  to cover this.
xin
Certified LabVIEW Architect (CLA)
Certified TestStand Architect (CTA)
(943 Views)
Ok, this is an exam question, but still: ask yourself what would be the best solution...
What makes the most sense for an operator, technician, developer, ....
(925 Views)
Apparently nothing is what makes sense because that's what the example exam does
Studying for CLA.
LabVIEW, inherit from social media habits!
(540 Views)
The Sample Exam does not cover those requirements. The Sample Exam is just an example of a passing exam, which only has to get a 70% or higher.
In these specific requirements, I would recommend using the Initialize SP25 step to have a conditional Additional Result that says if the step passed or failed. Then I might use a Post Expression, or a step after that to generate an error so the test terminates. The error could have verbiage like "After turning on power, the SP25 was not able to be communicated with. Terminated Test".
(523 Views)
(382 Views)
I think they want you to use the example test sequence for overriding engine callback of errors.
I got 18% on the test so take my advice with a grain of salt lol
CLA
(358 Views)
