Can two different sub sequences in main sequence can have same name subsequence but has different steps?
I have main teststand program that call three subsequnce(111.seq, 222.seq, 333.seq) for three different UUT test on same same station. Now these three subsequnce has another subsequnce call say "Button-LED test.seq". Can this individual "Button-LED test.seq" mentioned in each three UUT sequnce(111,222,333) can have different steps/contains insides it?
Example 111.seq --> "Button-LED test" ---> Step 1. verify setup button Step 2. Override 75 Step 3. Override 65 Step 4. Override 1 active
                 222.seq --> "Button-LED test" ---> Step 1. verify setup button Step 2. Override 35 Step 3. Override 1 active Step 4. Override 2 active
                 333.seq --> "Button-LED test" ---> Step 1. verify setup button Step 2. Override 65 Step 3. Override 1 active Step 4. Verify Override 1 Step 5. Wait
Amitabh
(4,204 Views)
It can as long as they are different sequence files. You can have more than one sequence file with the same name as long as they are located in different directories.
Another option is to have one sequence in "Button-LED test" with preconditions or "if" statements in it to execute differently based on who the caller is or better yet, based on parameters you pass into the sequence.
Hope this helps,
-Doug
(4,163 Views)
Thanks Doug. That make sense.
(4,158 Views)
