Cannot add a sequence to a project using API
I am trying to create a TestStand app completely with the API.  I have been able to create the workspace and add a project.  However, I cannot figure out how to add a sequence file to the project.  Below is my code.  The last few lines are how I tried to add the sequence file, but got an exception.
How do I add a sequence file to a project?
WorkspaceFile workspace = _testStandEngine.NewWorkspaceFile();
PropertyObjectFile workspaceFile = workspace.AsPropertyObjectFile();
workspaceFile.Path = @"C:\Released\TestStand\TestApp\TestApp.tsw";
workspaceFile.WriteFile(WriteFileFormat.WriteFileFormat_Current);
// create project file
PropertyObjectFile projectFile = _testStandEngine.NewPropertyObjectFile(PropertyObjectFileTypes.FileType_ProjectFile);
projectFile.Path = @"C:\Released\TestStand\TestApp\MyProject\MyProject.tpj";
projectFile.WriteFile(WriteFileFormat.WriteFileFormat_Current);
// add project to workspace
WorkspaceObject project = workspace.RootWorkspaceObject.NewFile(projectFile.Path);
workspace.RootWorkspaceObject.InsertObject(project, 0);
project.ProjectFile.WriteFile(WriteFileFormat.WriteFileFormat_Current);
// sequence file
PropertyObjectFile sequenceFile = _testStandEngine.NewPropertyObjectFile(PropertyObjectFileTypes.FileType_SequenceFile);
sequenceFile.Path = @"C:\Released\TestStand\TestApp\MyProject\Tests.seq";
sequenceFile.WriteFile(WriteFileFormat.WriteFileFormat_Current);
//*** throws an exception:
//*** "Attempting to insert non-project file into workspace."
WorkspaceObject sequence = workspace.RootWorkspaceObject.NewFile(sequenceFile.Path);
project.InsertObject(sequence, 0);
workspace.AsPropertyObjectFile().WriteFile(WriteFileFormat.WriteFileFormat_Current);
(2,738 Views)
You can't add sequence files to a workspace.  You have to add them to a project.  It's been a while since I've played with this but I think you need to do something like this:
projectAsObject = workspacefile.FindWorkSpaceObject(project path)
seqFileObject = projectAsObject.NewFile(SequenceFilePath)
projectAsObject.InsertObject(seqFileObject)
Again, been a while so I'm not quite sure on all the details.
jigg
CTA, CLA
testeract.com
(2,208 Views)
I believe I sorted out the details of your code, but still cannot add a sequence to a project.  I am able to create a sequence file and populate it, but just can't add it to my project.  See my revised code below.
I use a SequenceFile object since it seems the most straightforward for adding properties.  Note that to call InsertObject I had to call NewFile to get a WorkspaceObject object for my sequence file.  Also note that I sprinkled Save and Write methods around thinking that it might resolve my issue.  Perhaps I am not saving the 'correct' way or at the right time.
SequenceFile sequenceFile = _testStandEngine.NewSequenceFile();
Sequence newSequence = _testStandEngine.NewSequence();
newSequence.Name = "MyNewSequence";
PropertyObject locals = newSequence.Locals;
locals.NewSubProperty("MyBool", PropertyValueTypes.PropValType_Boolean, false, "", 0);
locals.NewSubProperty("MyNumber", PropertyValueTypes.PropValType_Number, false, "", 0);
sequenceFile.InsertSequenceEx(0, newSequence);
sequenceFile.Save(@"C:\Released\TestStand\TestApp\MyProject\Tests.seq");
WorkspaceObject projectAsObject = workspace.FindWorkspaceObject(projectFile.Path);
WorkspaceObject sequenceFileAsObject = projectAsObject.NewFile(@"C:\Released\TestStand\TestApp\MyProject\Tests.seq");
projectAsObject.InsertObject(sequenceFileAsObject, 0);
// save?
// save everything
(2,200 Views)
projectFile.IncChangeCount()
projectFile.SaveFileIfModified(False)
jigg
CTA, CLA
testeract.com
(2,197 Views)
You might need to do AsPropertyObjectFile() for the projectFile before calling IncChangeCount and SaveFileIfModified methods.
jigg
CTA, CLA
testeract.com
(2,194 Views)
I finally got it.  jiggawax's comments helped.  I found the article (https://forums.ni.com/t5/Example-Programs/Creating-and-Populating-a-Workspace-Using-the-TestStand-AP...) on which I based my code to be incomplete.  The complete solution is below.
My biggest problem was that it wasn't clear that WorkspaceObject.NewFile does not create a file, it only creates an object associated with a file.  For a sequence file, you must create the sequence file (various ways), save it, and then pass NewFile the path to the file.
const string ProjectFileName = @"C:\Released\TestStand\TestApp\MyProject\MyProject.tpj";
const string SequenceFileName = @"C:\Released\TestStand\TestApp\MyProject\Tests.seq";
const string WorkspaceFileName = @"C:\Released\TestStand\TestApp\TestApp.tsw";
// create workspace file
workspace.AsPropertyObjectFile().Path = WorkspaceFileName;
projectFile.Path = ProjectFileName;
WorkspaceObject projectObject = workspace.RootWorkspaceObject.NewFile(projectFile.Path);
workspace.RootWorkspaceObject.InsertObject(projectObject, 0);
// create sequence and add a variable to Locals
newSequence.Name = "MySequence";
// create sequence file, add sequence, and save
sequenceFile.Save(SequenceFileName);
// create WorkspaceObject for sequence file and insert it into project
WorkspaceObject sequenceObject = projectObject.NewFile(sequenceFile.Path);
projectObject.InsertObject(sequenceObject, 0);
// save the project file
projectObject.ProjectFile.WriteFile(WriteFileFormat.WriteFileFormat_Current);
// save the workspace
workspace.AsPropertyObjectFile().IncChangeCount();
(2,176 Views)
