12-12-2019 04:20 PM
WorkspaceFile workspace = _testStandEngine.NewWorkspaceFile();
PropertyObjectFile workspaceFile = workspace.AsPropertyObjectFile();
workspaceFile.Path = @"C:\Released\TestStand\TestApp\TestApp.tsw";
workspaceFile.WriteFile(WriteFileFormat.WriteFileFormat_Current);
// create project file
PropertyObjectFile projectFile = _testStandEngine.NewPropertyObjectFile(PropertyObjectFileTypes.FileType_ProjectFile);
projectFile.Path = @"C:\Released\TestStand\TestApp\MyProject\MyProject.tpj";
projectFile.WriteFile(WriteFileFormat.WriteFileFormat_Current);
// add project to workspace
WorkspaceObject project = workspace.RootWorkspaceObject.NewFile(projectFile.Path);
workspace.RootWorkspaceObject.InsertObject(project, 0);
project.ProjectFile.WriteFile(WriteFileFormat.WriteFileFormat_Current);
// sequence file
PropertyObjectFile sequenceFile = _testStandEngine.NewPropertyObjectFile(PropertyObjectFileTypes.FileType_SequenceFile);
sequenceFile.Path = @"C:\Released\TestStand\TestApp\MyProject\Tests.seq";
sequenceFile.WriteFile(WriteFileFormat.WriteFileFormat_Current);
//*** throws an exception:
//*** "Attempting to insert non-project file into workspace."
WorkspaceObject sequence = workspace.RootWorkspaceObject.NewFile(sequenceFile.Path);
project.InsertObject(sequence, 0);
workspace.AsPropertyObjectFile().WriteFile(WriteFileFormat.WriteFileFormat_Current);
12-16-2019 12:08 PM
You can't add sequence files to a workspace. You have to add them to a project. It's been a while since I've played with this but I think you need to do something like this:
projectAsObject = workspacefile.FindWorkSpaceObject(project path)
seqFileObject = projectAsObject.NewFile(SequenceFilePath)
projectAsObject.InsertObject(seqFileObject)
Again, been a while so I'm not quite sure on all the details.
12-16-2019 02:45 PM
I believe I sorted out the details of your code, but still cannot add a sequence to a project. I am able to create a sequence file and populate it, but just can't add it to my project. See my revised code below.
I use a SequenceFile object since it seems the most straightforward for adding properties. Note that to call InsertObject I had to call NewFile to get a WorkspaceObject object for my sequence file. Also note that I sprinkled Save and Write methods around thinking that it might resolve my issue. Perhaps I am not saving the 'correct' way or at the right time.
SequenceFile sequenceFile = _testStandEngine.NewSequenceFile();
Sequence newSequence = _testStandEngine.NewSequence();
newSequence.Name = "MyNewSequence";
PropertyObject locals = newSequence.Locals;
locals.NewSubProperty("MyBool", PropertyValueTypes.PropValType_Boolean, false, "", 0);
locals.NewSubProperty("MyNumber", PropertyValueTypes.PropValType_Number, false, "", 0);
sequenceFile.InsertSequenceEx(0, newSequence);
sequenceFile.Save(@"C:\Released\TestStand\TestApp\MyProject\Tests.seq");
WorkspaceObject projectAsObject = workspace.FindWorkspaceObject(projectFile.Path);
WorkspaceObject sequenceFileAsObject = projectAsObject.NewFile(@"C:\Released\TestStand\TestApp\MyProject\Tests.seq");
projectAsObject.InsertObject(sequenceFileAsObject, 0);
// save?
// save everything
12-16-2019 03:58 PM
projectFile.IncChangeCount()
projectFile.SaveFileIfModified(False)
12-16-2019 04:02 PM
You might need to do AsPropertyObjectFile() for the projectFile before calling IncChangeCount and SaveFileIfModified methods.
12-17-2019 09:47 AM
I finally got it. jiggawax's comments helped. I found the article (https://forums.ni.com/t5/Example-Programs/Creating-and-Populating-a-Workspace-Using-the-TestStand-AP...) on which I based my code to be incomplete. The complete solution is below.
My biggest problem was that it wasn't clear that WorkspaceObject.NewFile does not create a file, it only creates an object associated with a file. For a sequence file, you must create the sequence file (various ways), save it, and then pass NewFile the path to the file.
const string ProjectFileName = @"C:\Released\TestStand\TestApp\MyProject\MyProject.tpj";
const string SequenceFileName = @"C:\Released\TestStand\TestApp\MyProject\Tests.seq";
const string WorkspaceFileName = @"C:\Released\TestStand\TestApp\TestApp.tsw";
// create workspace file
workspace.AsPropertyObjectFile().Path = WorkspaceFileName;
projectFile.Path = ProjectFileName;
WorkspaceObject projectObject = workspace.RootWorkspaceObject.NewFile(projectFile.Path);
workspace.RootWorkspaceObject.InsertObject(projectObject, 0);
// create sequence and add a variable to Locals
newSequence.Name = "MySequence";
// create sequence file, add sequence, and save
sequenceFile.Save(SequenceFileName);
// create WorkspaceObject for sequence file and insert it into project
WorkspaceObject sequenceObject = projectObject.NewFile(sequenceFile.Path);
projectObject.InsertObject(sequenceObject, 0);
// save the project file
projectObject.ProjectFile.WriteFile(WriteFileFormat.WriteFileFormat_Current);
// save the workspace
workspace.AsPropertyObjectFile().IncChangeCount();
