Change sequence file properties from within seq file
Hello
I am using Teststand 2019 and i want to change the sequece file property "Sequence file globals" in the sequence file.
I use the batch model and i want to set it to "All executions share the same file globals". Is this possible and if yes how
(1,031 Views)
The variable is :
ThisContext.RunState.SequenceFile.FileGlobalsScope
I think default value is 0/
Probably you should call this during the loading itself...using load engine callback.
Ravi
(1,004 Views)
Accepted by Tonnie
oke thanks
I will try it
(999 Views)
