Change the RunState.Execution.Result.Status
Hi all,
In my sequence I use the  "SequenceFilePostStepFailure" & "SequenceFilePostStepRuntimeError"
Now in these Callbacks I ask the operator whether he has to end the test ?
If YES!  then   I call   RunState.Execution.Terminate(),
this makes the Parameters.Result.Status = Terminated  (in  PostUUT)
But I would like to show the actual  Status that could be "Error" Or "Failed"
So I store this in RunState.Execution.Result.Status Temporarily  & then later  in PostUUT Update Parameters.Result.Status
I  can also store this in some FileGlobal but still the question can I use the "RunState.Execution.Result.Status"?
(4,766 Views)
Hi aparab!
In the following properties of ResultStatus are no hints for manipulating the ResultStatus.
ResultStatus Property - NI TestStand™ 4.2 Help - National Instruments
But maybe the following example may help you:
Overriding SequenceFilePostStepRuntimeError Callback.seq
This example use the Parameters.Step.Result.Status.
(4,415 Views)
