11-20-2017 04:17 AM
i get an error by starting my secquence the first time.
The error Name: Code modules must be able to load.
I can eliminate the error when I unlock the button "log" for the Report.
After the unlocking i haven´t any Errors.
Now I lock the "log for Report" button again and try the sequence again. And now i haven´t any Errors, too.
I attached a file of an example subsequence where I have the error.
Can somebody help me why I get the error, and why I get the error just one time?
Kind Regards
11-22-2017 04:26 AM
Hi Andreas,
can you please try to open one of the TestStand Examples and observe if the error is happening there, too. You can find the examples under <TestStand Public>\Examples.
If the example program works, please upload the sequence file and a screenshot of the option you mentioned.
Best,
Melanie
11-22-2017 05:12 AM
thanks for your Reply.
The Examples are working.
I attached a screenshot of the error.
It doesn´t pay when you get the sequence because you havent the Hardware isn´t it?
Can you help me with this screenshot? Can you recognize the mistake?
Best
11-22-2017 05:12 AM
Best
11-22-2017 05:16 AM
Hi Andreas,
thank you for your reply.
Yes, I can not run the sequence, but I can take a look into the step configuration and the code module so I can get an idea of what is going wrong there. Can you please attach the sequence file and at lease one code module?
Best,
Melanie
11-27-2017 01:13 AM
thanks for your Support.
I have solved the Problem.
It was a LabVIEW Problem.
Kind Regards
