Command kind for break on step pass and break on each step
I have seen the command CommandKind_BreakOnStepFailure , which breaks on each step failure. I am searching for a command which breaks on each step pass and also breaks on each step. Is the Teststand provides this commands.
Anand
(2,315 Views)
There aren't Commands for those specific behaviours. the options are Break on Step Failure, Break on First Step or Break on Sequence Failure.
If you wanted to implement Breaking at any other time, you would need to manually invoke the method to Break.
Nic
Nico
Systems Engineer
Certified TestStand Architect Certified LabVIEW Architect
(2,291 Views)
Is it possible to implement custom functionality for command kind for step pass or each step?
(2,275 Views)
